Hi all
I'm struggling to find a decent 24mm for my a7ii. So far I've tried the: Yashica 24/2.8 ml (terrible corner performance), Canon nFD 24/2.8 (sharp but handling too stiff and strong distortion), Sigma 24/2.8 Super Wide II (even worse corner performance than the Yashica), Rokkor MC 24/2.8 (not bad, but softer than I would like).
I'm not a natural 24mm shooter (35mm is normally as wide as I go), so it's not exactly going to be glued to my camera. I'm thinking about giving the Zuiko 24/2.8 a go, but it's not the cheapest. Anyone got any recommendations? As an outside, I was wondering about the Nikkor 24/2.8 afd - anyone tried it with the a7ii?
Hi,
I use an original A7r and at one time I had both the Olympus 24 and the Minolta 24 MC (55mm filter ring version). I ended up selling the Olympus, the Rokkor was generally a bit sharper stopped down and a lot sharper wide open.
You could try focusing the 24 MC Rokkor at the borders (if your subject is positioned there) and at the working aperture, i.e. AFTER you've stopped down.
This because it has quite a bit of field curvature, and the focus shifts a bit when you stop it down. But if I focus it at the borders and at the working aperture then it gets pretty much the equal, at f/11, of my (great) Contax 28-85 (even more so getting closer to keep the frame identical) at both close distance and infinity
Thanks - it sounds like my technique could use a bit of work in that case.  I'll have another play and see if that helps.  I've reviewed some indoor sample in Lightroom and noticed a fair bit of flare from artificial lights (I was shooting with a screw in hood) .  Do you have similar issues with yours?
Yes, mine does that too. Part of it is the lens fault, part of it I suspect is the fact of using an adapter, because I've seen the same thing even with modern Canon etc. lenses used on a Metabones or a Commlite etc.
With the Minolta, and beside the possible troubles due to the adapter, this might depend on two things: first, the older anti reflective coatings aren't as good as the new ones; secondly, Minolta went along another road in comparison with pretty much all other manufacturers. Instead of trying to maximize the efficiency of the anti reflective coating for each specific lens, they sacrificed a bit of resistance to flare to have a perfectly matched color rendering along the entire lens range.
Even the Contax 28-85 MM that I already cited, that's possibly the worst performing lens in terms of flare resistance out of the entire Contax lineup, still holds MUCH better.
If a 24mm focal length is not a lock, and you can live with a 28mm, a Contax 28/2.8 could be an interesting proposition (or probably, at that point, even the 28/2 Sony FE).
I thought that might be the cases - I'm tempted to give the Canon nFD 24/2 a shot, as it's supposed to be a reasonable improvement over the 24/2.8 and should have more modern coating than the Minolta MC.
I never really got on with the 28mm focal length - I originally sold my 35/2.8 and replaced it with the 28/2 (as it was faster and I hoped it would be a good compromise between a 24mm and 35mm).  I more or less instantly regretted the decision, sadly.  Obviously it's not going to have Zeiss rendering, but the distortion made it a pain to compose with and a nightmare to deal with in post (even with a DXO profile).  Needless to say, first thing I did was to reverse the decision and replace it with another 35mm/2.8.  If there was a 28mm Batis, I might reconsider, but the 35/2.8 is so versatile that a Batis would have to be stunning to get me to part with it.
If only there was an affordable native 24mm...
Agree 100%; the 2 lenses I need, and that Sony stubbornly refuses to release preferring instead stuffing the lineup with 50mm lenses, are a reasonably priced and small 24/2.8 and a 85/1.8 or a 100/2.
I really don't get this obsession where everyone has to shoot with the shallowest dof possible, and your subject will be left with just an eyelash in focus! :)
Yep - I really don't understand why they haven't done an FE version of the a-mount plastic fantastic line...
I was using an AiS 24/2.8 on a Metabones but
switched to the A-mount, actually Maxxum AF
mount, 24/2.8 cuz I could then enjoy auto-iris
convenience. The lens is much lighter but quite
sturdy since it has no external focusing motion.
The focusing ring is narrow but easy to access
and easy to turn without being sloppy or loose
or "free spinning". IOW "just right". I don't use
the OEM clip-on hood cuz it crowds the focus
ring. A generic threaded hood is no problem cuz
it sits about 1/2 inch further forward. The thread
fit hood is actually a convenience as it puts my
fingers right exactly where they need to be with
no interference, and acoarst it sits there reeeal
solid cuz the lens has internal focusing :-)
You seem a bit concerned about IQ and you'd
hafta ask someone else about that. I'm in the
IILGIIG* club, possibly senior founding member.
*  If it LOOKS good, it IS good.
The Maxxum isn't bad - I've only used on an a77, but I was quite pleased with it.  Which adapter are you using?  From memory, it was quite fiddly in mf...
I am a bit surprised concerning your comments on the Sigma 24mm Superwide II f2.8; I have a PK fit one that I use with a K&F adapter, and I find the corners are pretty sharp, except at f2.8. I find that it's a sharper lens than the FE24-70mm f4 at 24mm.
Sounds like you won the sample lottery!  The centre of mine was excellent wide open, but i had to stop down to f11 before the corners were acceptable.  Guessing Sigma's QC hasn't changed that much over the years...
Regarding Minolta SR, there is also the 24mm VFC (if you can find it), which has adjustable field curvature. With the right setting, it's really sharp.
All adapters are not created equal. It is possible to get a cheap adapter that performs flawlessly; the reverse is also true. There may also be copy variation at play here, but with a Novoflex adapter my tiny Oly 24mm f/2.8 is a stellar performer. Stopped down it is sharper than my Canon 24mm f/1.4 L adapted via a Novoflex.
The perfect flange distance of the adapter is much more important for wides with floating focusing than for any other prime lens.
Mechanically, it's not "fiddley". Visually, on an old
Maxxum film camera, MF was eyeball fiddley due
to great DoF and to inadequate focusing screens.
But on a live view with magnified MF assist there
is no longer such a problem in the least.
The adapter I use is the LAEA3. Since it is Sony's
own adapter, everything fits beautifully and flange
focus seems to be perfect.
