September 23, 20169 yr I have the Sony a6000 and I recently purchased the Sony SEL1670Z lens. When I turn the barrel of the lens, it will make a "click" sound whenever it passed the "24mm" mark. More specifically, when I rotate it from 16-70, the sound is made as it passes "24mm". When I turn it from 70-16, it makes a louder click sound as it passed "24mm". Is the clicking sound normal? Thanks, Andy
Advertisement Hi AndyWolan, You may be interested in this: Clicking sound with Sony SEL1670Z 4f/16-70mm lens . I'm sure you'll find what you were looking for!
September 23, 20169 yr I don't think so, a modern lens is supposed to be NOISELESS. On my 10-18, I had a problem, a sort of crrrrrrrr when focusing. I sent it to Sony. I think it was broken plastic gears.
September 23, 20169 yr Hello together! I have both the Sony E 10-18mm and the Sony E 16-70 ZA.Both lenses produce beautiful pictures, but no noise.If your lenses are defective sends it to the Sony service.
September 24, 20169 yr Author Yikes! That stinks. Good thing I bought an extended warranty on this lens. I'll return it to the store and let them deal with it.
September 24, 20169 yr Yikes! That stinks. Good thing I bought an extended warranty on this lens. I'll return it to the store and let them deal with it. Return it for replacement if your warranty provides for that. Sony service has a horrible reputation.
September 27, 20169 yr I had the same click with my SEL1670Z copy. Sony support was so far beyond useless that I won't even mention their response. Other than the annoying click itself, there seemed to be no other issues at all. It's probably normal for that lens and completely harmless in the long run. Even if they send you a new copy under warranty there's probably a chance the replacement would have the same issue. So if that's the only problem with your lens, I wouldn't waste any more time on it. Just let it be.
October 3, 20169 yr Return it for replacement if your warranty provides for that. Sony service has a horrible reputation. Although I cannot speak for their lens service I can, albeit anecdotally, speak for their service when replacing the lens assembly in my RX100M3 which I believe was a too frequent for comfort occurrence for them. Took to shop and back inside 10 working days all fixed.
October 19, 20169 yr I have the sel1650 ,no clicking here. Unless you are running in video mode, then you can hear the image stabilization running in your video.
March 15, 20196 yr I also experience the same problem. Image quality wise, the lens produces sharp and beautiful image nonetheless. I think I didn't hear it at the first couple of days, after that it started clicking when zooming out at 24mm.
