June 28, 20169 yr Hello Everyone, I have searched this question in the forum, but couldn't find any solution. Is there a way, Without any other equipment than the camera and External mic, to create a mix between the internal audio of the camera and the audio comes from the external mic (Even if the stereo audio of the external becomes mono). The final result should be - Channel 1 - external Channel 2 - internal Thanks
June 29, 20169 yr There is no way to do that within the camera. Best option is get a second recorder for your external mic at that point. If you want a backwards, and likely low quality way to get it inside the camera, you would need to have a stereo out from the headphone jack of the camera, in to a portable mixer, combine it with the separate channel from your external mic, and put out a 2 channel stereo signal back in to the mic jack of the camera with another 3.5mm stereo cable.
June 29, 20169 yr Why do it this way? You could end up with botched audio and the entire shoot ends up worthless. If I wanted to sabotage a shoot your approach is exactly the way I'd do it. Send the external mic into its own recorder then you have a better chance of rescuing a shoot where audio on one capture is unusable. On my one man, 3 camera band shoots I have 2 locked down cameras and the mobile one giving me 3 separate audio tracks PLUS the board audio captured from the sound mans mixer. Synch all using PluralEyes (board audio for main quality and on-board camera audio at much lower volume for event ambiance) and it's off to the races. Your way introduces so many variables that may not be correctable in post. Bad audio will ruin the greatest of video (except for porn).
June 29, 20169 yr There is no way to do that within the camera. Best option is get a second recorder for your external mic at that point. If you want a backwards, and likely low quality way to get it inside the camera, you would need to have a stereo out from the headphone jack of the camera, in to a portable mixer, combine it with the separate channel from your external mic, and put out a 2 channel stereo signal back in to the mic jack of the camera with another 3.5mm stereo cable. Despite that the signal is passing thru extra devices, you are nevertheless sending the camera's output back into the camera's input without involving any time delay. Looks like a feedback loop to me.
June 29, 20169 yr I isolation-mount a handheld-type stereo field recorder onto a bracket above the camera, which acoarst feeds into the camera's "mic in" jack. This recorder has very decent built-in mics [typical of such recorders]. Some of these recorders will allow mixing their built-in mics with external mics connected thru the recorder's "mic in" ... and allow balancing between. This involves less hardware compared to involving an external mixer, cuz the mic on the camera bracket has its own internal mixing capability between its built-in mics and additional outboard mics. ######################################### ######################################### No "Geek Warning" here ... this is the Good Stuff : One major bonus here is that you are using a recorder as a mic, so you can either leave it on "standby", such that it's just a mic, or you can hit "record" and record a back-up audio track. Another bonus, regardless of whether you hit "record", is that a recorder-used-as-mic has it's own record-gain and output level controls, with its own small LCD panel displaying record level etc. You can match the output level of the recorder and the input gain of the camera such that you will no longer need to further refer to the camera's audio menu. You control your audio from the field recorder ... using its input and output dials and its LCD readout for recording level and operational status.
June 29, 20169 yr Despite that the signal is passing thru extra devices, you are nevertheless sending the camera's output back into the camera's input without involving any time delay. Looks like a feedback loop to me. Yep, you are right. that wouldn't work either. Would still have to just be in to the external recorder. No way for the a7s to record both internal and external audio. Might sound interesting though!
June 30, 20169 yr I can't see going to much effort to set up a rig that blends an external mic with the camera's internal mics. If the camera had a quick-and-dirty click-the-menu method, then I can see some uses for it, but even if the internal mics were much better than they typically are, you still have handling noise and such. ============================= Altho quite useable for some stuff, I don't care much for internal camera mics, but then my standard is music. My own use is strictly personal, and for my purpose I care much more about audio than visual content. Basically, my video is rather like "home movies" that accompany a decent "reference recording". This is common in club level performances, so common that GoPro now provides a special musician's model with premium sound ! Anywho, I don't own or want any sort of GoPro, but have various field recorders on hand that I'd acquired for audio-only, and lately I've hooked them up to SLRs for "music video". NO relation to MTV, or YooToob or etc. And yes, I said, "SLRs". So sue me. It's just cuz they have those BIG batteries :-) Size DOES matter here. ============================= If you wanna try "recorder-as-mic", the smallest and least expensive is a Zoom H-1 at $100, sometimes less. It doesn't offer mixing between its onboard mics and its "mic in" jack, but it does provide the advantage of a decent stereo mic with adjustable record level and output level and a record level meter. It has a 1/4-20 thread for mounting to whatever. It goes directly into Record Standby as soon as you power it on, which allows you to immediately use it as a mic. Hit the red button and it records. You can set all your levels in Record Standby. If you want in-recorder mixing between the recorder's own mics and its "mic in" jacks, count on tripling the price and the size. Most of the size increase is due to bigger onboard stereo mic array. Also the LCD panel is wider and offers more info. Also, buttons, dials, etc are bigger and better arranged. Even with the tiny Zoom H-1, I'm using a bracket [an adapted Olde Skool flash bracket], and I can easily put one of the larger field recorders onto it. Every field recorder I've seen has a 1/4-20 socket. P.S. It's worth looking for a bracket that does NOT cover your battery door, if you use 'Individual-Snack-Size' Sony batteries :-)
July 5, 20169 yr Author Thank you all for your answers Thank Golem for the detailed answer and the valuable information ! Jarbil
