Hello,
I just recently purchased a Fotodiox Canon Ef to Nex mount adapter, I have a shoot tomorrow morning, so I'm hoping to get some help tonight. Every canon lens I own works on that adapter no problem, however, only one lens, the lens I would really like to use does not seem to fit into the adapter properly. My canon ef-s 10-22mm does not seem to turn into the adapter. There is no visible obstruction, the adapter came straight out of the package. I line up the white does and rotate moves slightly but locks up and wont slide into the place properly.
Any help or guide to resources that can help would be greatly appreciated!
~Thanks
This is the whole ball of wax:
"I just recently purchased a Fotodiox Canon Ef
morning"
Do not attempt using the 10-22 tomorrow morning.
Leave it home. Doesn't matter how badly you think
you need it.
Maybe it's not "think you need it". Maybe it's really
essential. We've all had to struggle thru gigs where
something essential went belly up. It's bad enuf to
encounter that unexpectedly, suddenly, in front of a
client, but we get thru. You have an advantage over
that situation. You will not suffer the unexpected in
the presence of a client. You may indeed struggle
the same, but at least you will conceal it better cuz
you weren't taken by surprise. You have hours to
figger out a workaround. With a surprise failure you
have only minutes. Aren't you blessed ?
Leave the [possibly essential] 10-22 at home.
Thank me later.
I'm gonna guess that all those other lenses
are in EF mount, and that Fotodiox failed to
consider the EF-S mount. Maybe I'm off the
mark, but you'd best figger that out AFTER
tomorrow's successful and uneventful shoot.
" just recently purchased a Fotodiox
Canon Ef to Nex mount adapter, ..... "
Hopefully, "recently" means you are still
within the window for a merchandise return
so you can get a better adapter.
How did the next morning go ?
I also had a shoot yesterday involving an adapter but ....
1. It's not an "economy model", and ....
2. It's already been in use now for several weeks, so no sooprises, and ....
3. I brought a minimal but capable back-up outfit not involving any adapter.
Pleeeeease never put yourself in a position that could result in a panicky
post such as your OP in this thread. Look both ways before you cross the
street [etc etc].
