A few photos from the cruise on Lake Argentino, being in the Argentine Patagonia
A77 + sony 70-200/2.8
A99 + zeiss 24-70/2.8
sorry, I don't see any images?
I use to do the same while on safari ;-)
Telephoto (70-400) onto the A77, landscape lens (24-70 CZ) onto the A850.
Much more convenient to switch cameras than to swap lenses and you have a backup camera if one should fail.
No fun to go on a hike with that backpack though.
And... you get special attention at every airport security control.
Funnily everyone assumes you´re a professional when carrying around two cameras.
Great photos trubak, I especially like the 2nd and 4th.
