Hello everyone,
I would appreciate it if anyone has encountered this issue.
I am a dance photographer and own a Sony Alpha 9 II camera.
I have been shooting with this camera for about two years.
I use the electronic shutter and, of course, shoot at a high continuous shooting rate.
My memory cards are SanDisk with a speed of 300MB/s.
One of my lenses is a 70-200mm f/2.8.
About three weeks ago, I suddenly noticed that after 103 consecutive shots, I sometimes can't press the shutter button to take another burst of images (which never happened before).
This has happened three times.
I went to a camera repair lab, but they haven't taken it for inspection yet.
They said they had never encountered this issue before and suggested I try replacing the memory card.
Has anyone experienced this?
Thank you!
    • I'm interested in creating videos with my camera. I'd like to automate the movement of the camera (pan left/right, zoom in/out, turn left/right, etc.) I believe I need a motorized camera tripod. Can you recommend a motorised camera tripod?
    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
