August 19, 20223 yr Took the lens hood off to clean the glass and it threaded in wrong and now it wont come off. The press to release button will still click and you have a slight amount of turn before it jsut doesnt move at all. Any tips or ideas on what to do here
Advertisement Hello thestuckhood, You may be interested in this: sony 28-135mm G lens hood STUCK HELP . I'm sure you'll find what you were looking for!
August 22, 20223 yr Try wrapping a dry warm small towel around the hood. The heat from the towel will cause the hood to expand slightly and it should be a little looser. Make sure you don't heat up the lens. After a few minutes, try to turn it with out pushing it toward the lens, instead pull it gently away from the lens while turning it.You can keep it warm using a hairdryer but on a low setting the hood might warp if to much heat applied GOOD LUCK, Edited August 22, 20223 yr by Wee-Malky added
