December 10, 20205 yr So I made a mistake. While traveling on an airplane, pre-Covid times, I put my camera into my luggage, rather than bringing it in a carry-on. Because of the extreme cold, my camera battery, from what I believe, must have expanded inside the camera. To my surprise, a pair of fresh batteries turned the camera on! I replaced each battery that was damaged during this flight, however after a few seconds the camera displays the incompatible battery message, then turns off. I should consider myself lucky that nothing worse happened, but is there anything that I can do to fix my Sony a7R? I don’t mind ordering pieces online and fixing it myself. Let me know your thoughts :)
Advertisement Hi Honza Mali, You may be interested in this: Battery Expanded Inside Sony A7R . I'm sure you'll find what you were looking for!
December 11, 20205 yr The hold may not be as comfortable as the cabin, but I'm told it is heated. Our baggage is not subjected to -40C or worse of the outside sky.
