I have a Sony A7ii and two Sony lenses (28-70 & 24-240 zooms).  The other day I took off the lens to blow dust off of the sensor.  When I reattached the lens, it wouldn't auto focus, and the aperture displayed with a dash instead of the number.  I reattached the lens, tried a different lens, replaced the battery etc...  I called Sony, they told me to gently wipe the copper contacts on both the camera and lens with a cloth, and the problem resolved itself.  The next day, the problem re-occured a couple of times without the lens ever being removed.  One other time, I couldn't get the camera to power on at all.  I flipped the switch several times, and it finally came on.  It's one month out of the one-year warranty (of course).  If any of you have had similar problems, or have a solution, I would love your input.
Does it happen with both lenses or just the 28-70? If it's both it's more likely to be the camera rather than the lens.
If you suspect the camera there's not a lot to do on your own. I would suggest cleaning the contacts carefully with rubbing alcohol, doing a factory reset and leaving it without a battery and memory card for a couple of days.
If that doesn't solve it you should get a quote for repairs.
You are correct, it has happened with both lenses which also led me to believe it was the contacts on the camera more than anything.  I suppose I'm glad to hear that there weren't a lot of people out there with the same problem which would indicate some kind of defect.
Connection issues aren't that unusual. I've had it on several cameras and lenses that I use frequently. Hopefully a clean and reset will fix it.
P.S. I forgot to mention that it's worth checking if camera and lens firmware is up to date and if not updating them. I forgot to mention it because I do it as a matter of course, but people may have different habits.
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
