Posts
I am considering buying an A7 mirrorless full frame but considering the use of my 600mm and other lens ( fulll frame ) which were used on my A99. Is there an adaptor for using A-mount lens on E-mount cameras? What are the issues using these adaptors? Things like autofocus etc. Is traveling with them going to be a problem? Thanks for any pointers.
Digital sensors do not suffer from reciprocity failure in the way film does, they are linear. Cameratose's suggestion is the most likely. Also with such long exposures, there could be subtle changes in lighting levels between the two shots taken at seperate times, that the human eye could not perceive.
Topics
