August 7, 20214 yr Hello! I have problem with my a6500 ;( On some video shoots i encountered random recording stops. When it happens - after few or several seconds camera just stops recording and shows Memory Recall screen. I did factory reset, SD cards are new, or i do format them before every use (Sandisc Extreme). Latest firmware. pls help!
Advertisement Hi Signvetica, You may be interested in this: Sony a6500 stops recording . I'm sure you'll find what you were looking for!
September 26, 20214 yr The same problem. What lenses are you using then? In my case it happens with sigma 30, viltrox 56, Carl Zeiss Sonnar T 135. Never with sony 18-105...
September 29, 20214 yr I have this problem on two A6500s. On different memory cards and batteries. I suspect a problem with the lenses, stabilization, or with the charger - this year I bought a newell dual charger, maybe it has an impact on the problem with the batteries.
October 19, 20214 yr The internal battery is probably the problem. I have been charging the batteries in an external charger for a long time and the problem has almost always appeared. After charging the battery inside the camera with the usb cable, the problem is fixed. I left the camera connected for 24 hours.
March 20, 20223 yr a6500 just stops recording and shows Memory Recall screen, why? battery original and tried anothers = same problem sd card differents brands always class10 high speedy = same problem battery full 100% or low battery, pluged or not in power bank = same problem use in a tripod = same problem use with ronin s = same problem i tried every option and the issue continues, its a random problem can someone help?
