Nex6 Upgrade question
New member here, I use the camera as an artist looking for painting subjects. I’d like to upgrade resolution but I’d like to keep some of the 6’s creative style features. In particular I like the black and white shooting with selected image color included, red, blue, etc. Also I like the color options in manual focus peaking. Are these carry overs to the A6000, for instance?
