Next portrait lens for full body shots at close range.
Been doing modeling photography for a a little while. I own a 50 and 30 mm lens however still feel I have to stand  a fair distance from the model to get full shots. Great for headshots though any suggestions on a lens that I can use close up to my subject and get alot of their body in shot and can go to 1.8 and get good blurry backgrounds.  Would a wide angle be good my budget is around the £300 mark.
Sigma 16mm f/1.4 might just fit your budget, though I doubt such a wide focal length is useable for model shooting due to perspective distortion. But that's up to your artistic taste to decide.
Another great option is the Sony Zeiss 24mm f/1.8, though that one is out of your budget.
I have shot mid body portraits with the Sigma 16mm and got very good results, I'd recommend it if you are not too picky about distortion. Lightroom has a distortion correction profile for this lens which might help. However, for full body shoots and creamy bokeh I'll better suggest a proper lens like the 85mm 1.8 but the distance factor will increase as well as the price. In Ebay you could find it as low as 500 USD.
Can't go wrong with 85/1.8 - forget the 1.4, just too expensive unless you are taking shots for a living.
Also, Sigma have released a full range of primes for FF fe line.
My advice would be to try out a Sigma 85 for your close in/portrait work.
