A6000 Color Way Off
I haven't been able to identify the species yet in order to be able to find other images of it but the two yellow stripes on the wings are not yellow at all to the naked eye they are clearly pink. I have also found this camera to misinterpret butterfly wing color on another occasion. Here I shot first with out flash and then with flash hoping to help the camera identify the color but no change. I wish I'd had the presence of mind to run for my cel phone to see if it's camera interpreted correctly but I didn't. I see that the camera has two color space options: sRGB and Adobe RGB. I had the camera set to the former and I haven't tried the latter yet so I wonder it would have seen the colors correctly.
With out Flash
With Flash
Are colors off for all your shots?  As an advanced member I assume you understand picture profiles, temperature, JPEG vs RAW, etc?  A photo of a color balance chart might be helpful too.   You could try shooting a neutral gray card and manually choosing temperature.  Butterfly wing color may be a special circumstance since to my eye many of them seem to have a "glowing" quality to them.
Not all colors reproduce faithfully and this may be one of those cases. look at tinplater's reply for good suggestions.  To give you an example of color not reproducing correctly.  Several years ago in the film days the nations largest chain of photo processing labs had a national sales meeting with about 80 sales reps in attendance.  They took a group photo with all of them wearing green sport coats.  To the naked eye they all matched, however some coats were maybe a decade old and others purchased just before the meeting.  When the group photo was taken there were about 12 shapes of green.  Since this was pre-photoshop time they ended up printing the photo in black and white even though the company name included the word color.
