Hi Guys
Any of you guys using a a7 Body with your Leica Glass.......
  • What adapters are you using
  • Any complaints
  • Tips advice
  • What about Wide Angle Lenses..............
Any feedback would be much appreciated
Neil
I use a Summicron-M 50/2, it works pretty good with the A7II and a Voigtlander VM-E close up adapter, I use it everyday, pre-ordered the Sony 90FE  macro, and probably get the Batis 25mm then I would be set.
Leica R should be no problem at all. I had 4, still have 2, including Elmarit R 28mm vII.
For Leica M, the only wides that work well without the Kolari modification are the WATE (16-18-21), and the Summiluxes 21 and 24.
I would hesitate to put rf lenses on a
digital camera of ANY sort. There's a
reason that, frinstintz, zeiss's super
hot shot normal lens is a distagon when
back in the film era it woulda been a
planar. It's kinda ironic that digital
cameras can have very shallow bodies,
but need to have their lenses built to
stand well distant from the "film plane"
[thus the distagon normal lens]. Thaz
why Leica R-lenses would be generally
preferable to M-lenses.
I guess, the Leica R-glasses with adapter, should be better especially in the WA range, as the compact Leica M-glasses, because of the
flange distance. People saying, that the Leica M WA lenses having optical problems in the WA corner!
Yes, the 60 mm Macro Elmarit (version 3, no ROM) is my preferred standard lens on R bodies.I've used it now on the a7 II, results are great, no probs whatsoever. Macro and standard shots excellent. Performs better than the Summicron 2.0.
Here is a macro shot with the Macro Elmarit, ISO 1600, F probably 8, I dont keep track and the A7 wont't record.
and a "normal" shot, ISO 1600, F probably 5.6, Both shots as JPEG files right out of the A7, no processing, nothing done except compression to get file size below 1 MB.
