A7R2, Switching between FF and APS-C size images
sundial215
I use my A7r2 with a 70-330 FE SEL Lens and would like to easily switch between FF and APS-C size when in the field without looking through the menus.  I tried to set this up using the Memory Recall capability only to find that I could not set it to work.  Is it possible to set this function to a button, or, is it possible to use the Memory Recall function in some manner that is not apparent from the material I reviewed?
Edited by sundial215
minor word change
I wonder what the reasoning behind omitting that function from button assignment is?  Was it an oversight or is there some reason stemming from the way it is coded in firmware that prohibits assignment of the function to a button, or to Custom Setting either 1 or 2?  As I get to use this Camera, I generally find the controls and menus well thought out and in comparison to my prior D810, easer to use while in the field.
