I have a Contax N 24-85 adapted to canon EF mount by Conurus. This lens works fine on a Canon. But with a Metabones IV on my a7Rii there are some issues. When I switch on the camera I have no aperture controll (stuck on f8.0) and no autofocus. Switch it off and back on again..... voila it works, most of the time. But some times it goes black (the viewfinder that is) and I have to turn it on/off many times before I establish a working connection between the camera and the lens. I'm currently using fw 0,57 (it was a litle better than 0,58) Anyone else had this or similar problem and got it solved??? Help needed.
