Any ideas how wide angle M-lenses will work on a7r II?
Is there any experience published yet of pre production-tests how the new a7r II will work with classical m-lenses (leica or zeiss)?
The alpha 7r has problems with color shift and vignetting... does the new sensor of the alpha 7r II a better job?
Martin
There is no special mention on this on the Sony press text.
That's real a surprise :D
Obviously none of the camera-tester had a chance to take photos with lenses other than sony original E-mount.
    • Shooting a cactus flower is probably where you do want to have nice bokeh. I can't recall which camera you're shooting, or maybe you haven't said, but using live view you can see what the shot will look like before you press the button. Try setting up on a flower or something stationary where you can control the background and see the changes different settings make.
