DrJohn Posted July 18, 2018 Share Posted July 18, 2018 I'm planning to buy the Sony 70-300 mm FE lens for wild life photography. I heard it works well as a macro lens too. Has anyone tried it for macro photography? John Link to post Share on other sites More sharing options...
Advertisement Posted July 18, 2018 Posted July 18, 2018 Hi DrJohn, Take a look here 70-300 mm FE lens for Macro?. I'm sure you'll find what you were looking for!
sixzeiss Posted July 18, 2018 Share Posted July 18, 2018 At least on paper its going to be OK. The 0.31x reproduction ratio is probably good enough. The Sony macro lens has reproduction ration 1.0x (3 times larger), but for many not too small things, 0.31x would do the trick. I use a Zeiss Milvus 50mm macro lens, many times at 1:3 (0.33x) ratio, and I find it to be good. Link to post Share on other sites More sharing options...
DrJohn Posted July 18, 2018 Author Share Posted July 18, 2018 28 minutes ago, sixzeiss said: At least on paper its going to be OK. The 0.31x reproduction ratio is probably good enough. The Sony macro lens has reproduction ration 1.0x (3 times larger), but for many not too small things, 0.31x would do the trick. I use a Zeiss Milvus 50mm macro lens, many times at 1:3 (0.33x) ratio, and I find it to be good. Great to know. thanks, John Link to post Share on other sites More sharing options...
thefsb Posted July 20, 2018 Share Posted July 20, 2018 Yes. There's [ample evidence](https://www.flickr.com/photos/lescatalpas/) that it works very well for close-ups, despite not being technically a macro lens. If you don't need a fast lens then this one is pretty versatile. Link to post Share on other sites More sharing options...
Lescatalpas Posted July 20, 2018 Share Posted July 20, 2018 There is an extensieve topic on this lens in the full frame lens chapter. Link to post Share on other sites More sharing options...
DrJohn Posted July 20, 2018 Author Share Posted July 20, 2018 5 hours ago, Lescatalpas said: There is an extensieve topic on this lens in the full frame lens chapter. Whoops. I thought that is where I posted this. I made a mistake. John Link to post Share on other sites More sharing options...
