APS-C lenses on A9 7Riii
6 hours ago, Keith Forman said:
You can't use those lenses in full-frame mode.
Wrong. You can use them in full frame mode, but they are likely to vignette.
By default the camera will automatically turn on crop mode with an APS-C lens, but you can switch the camera from auto crop to manual, then turn off crop mode.
Main menu item: APS-C/Super 35mm (On A7Riii, page one of fourteen in the Quality/Image Size1 tab)
First sub-menu item: APS-C S35 Shooting - Switch from Auto to Manual
Second sub-menu item: APS-C S35: Shoot. - Turn APS-C off to shoot FF with an APS-C lens
On 7/5/2018 at 4:25 PM, Keith Forman said:
They do not vignette. They cut off about 20% of the image hitting the sensor in full frame mode.
When you shoot them in APS-C mode, yes. But as I noted above, you can actually turn on full frame mode and depending on the lens, they may or may not vignette depending on how much of an image circle the lens actually projects.
For example, the following picture was taken with the SEL1018 APS-C lens @13mm on my FF A7Riii in FF mode.
