June 27, 20187 yr Hi, I just brought the Sony 6300. When changing up the settings i haven't got the option to to change to 4K 24fps and 1080 120fps. On the File format XAVC S HD and the options for record settings: 50p 50M, 25p 50M, 100p 100M and 100p 60M. Here i should have the option to change to 120p 100M but don't. If you know why or have any theories please respond will be a great help! Would show a picture but only aloud to upload 0.98MB! Thanks, Peter
June 27, 20187 yr These are the options according to the manual, if you don't have these then check that you have the most up-to-date firmware. Also; Edited June 27, 20187 yr by LiveShots
June 27, 20187 yr I think you have to change from PAL to NTSC to access the frame rates based on 60. PAL is based on 50.
