16/2.8 crop lens on FF body
Username
It helps to remove the rear baffle which
is really easy. Three little screws NOT
secured with Locktite or other bonding
material. I decided to Dremel out the
baffle and screw it back into place,
which results in the coverage shown.
Full sensor, no cropping:
It makes in-camera panoramas from
about 180 up to 345 degrees, depending
on the format, shaped by menu choices.
I was using a ball head, so there's no long
handle for smooth panning, and it looks
like such a handle is a good idea.  Below
are size reduced but otherwise not edited,
straight out of camera panoramas:
Edited by Username
