Noise issue
On 6/12/2018 at 12:35 PM, anna93 said:
Hello,
I bought a sony α6500 a month ago. I used it to take some pictures
indoors and I had to put ISO 320 but there is a big amount of noise
in the picture. Is it normal?
No.
ISO 320 should not be noisy. It would have a bit
of noise if you badly underexpose the image but
otherwise  ISO 320 is very clean.
This is ISO 400. It's also the old Nex-7 which is
definitely noisier than any recent a6xxx camera.
Edited by Username
