Sign in to follow this
geoffreyg123
Sony 90mm macro looks dull and washed out?
I recently got the 90mm macro with high hopes.
I'm not sure if it's supposed to look so washed out and soft, but I feel like it maybe shouldn't. I couldn't load a whole raw file up here so i exported to JPEG through camera raw (completely untouched from raw). Please let me know if you think this is acceptable from this lens.
Thanks
Share this post
Hi,
Yes I'm aware that it's raw. It's just that with the 50mm macro taking a very similar shot with the same settings, that file is much less washed out with more contrast.
I just want to know if this is something to expect with the 90mm...
Thanks
Share this post
The black point is raised quite a bit in the file. That's why the shadows are washed out.
It's a settings error, either in the camera or in camera raw.
The photo can be saved by dropping black in your software. But you should check your settings so you get a correct histogram for future photos.
Share this post
Geoffreyg123 , I wouldn't be happy with those results, but it looks like there may be a setting problems with your camera. I would try shooting in automatic just to see if that makes a difference.
Share this post
I have not experienced any washed out results with the 90 mm. Below 2 screenprints from LR, orchid original (bottem) is a raw imported into LR, nothing done to it other then the LR profile applied during the import. Orchid adjusted (top)  is with my own preferred setting.   ISO250 f/8 at 1/40sec.
Edited by Lescatalpas
Share this post
Like I said, there's a technical flaw in the file. The black point is raised to about 25 (should be between 0 and 4). That's all there is to it.
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
    • Your camera settings seem ok so no issue there. Be sure to disable stabilization when shooting from a tripod as your camera will try to compensate for shake that isn't there. This might result in a slight blur. It's quite difficult to assess your photos (am on phone atm). On the second photo it seems to be a depth of field / focus plane issue: the buildings in the back seem sharper than the trees/foliage. Same with the last image: focus seems to be more on the lightpost than on the building
    • I found another site that confirmed what you said, it seems I can still assign the focus hold button to eye af and then if I am using a spot focus area pressing the focus hold will override the spot and snap on to the eye. 🙂
    • I'm not exactly sure but it seems your help reference is outdated: initially it worked like that on the A7(R)III but with a certain firmware update these cameras got a feature called 'real-time Eye-AF', removing the need to press a button to engage Eye-AF.
    • Hi, I switched from Canon a while ago but I am struggling to understand and use my A7iii well, I've watched loads of tutorials but still find myself forgetting where stuff is in the menu although I've set some in the FN menu now.  I've read most people use the focus hold button on the lens for eye af so I followed this, http://support.d-imaging.sony.co.jp/support/ilc/eyeaf/en/index.html I also have face/Eye Prty in AF - ON, Subject Detection - Human, Face Dtct Frame Dsp - ON and Animal
    • Boa tarde. Minha primeira vez aqui. Tenho receio de atualizar o firmware da minha câmera. Então minha pergunta, é seguro, pode acontecer de travar a câmera ou acontecer de dar algum problema????? Outra dúvida, meu cabo USB não é o da Sony, posso usar esse??? Obrigado    Good afternoon.  My first time here.  I'm afraid to update my camera's firmware.  So my question, is it safe, can it happen to lock the camera or happen to give some problem ?????  Another question, my USB cable is not
