Sony A7s ii with Rokinon Cine Lens
I believe there's a place where you can 'dial in' the mm setting of the lens attached when it's a non communicating lens and can select specifically 85mm when the Rok 85mm is mounted. I may be confusing this with some of my other cameras but I loosely remember coming across this option on a A7Sii.
You'll need to turn on the "Release shutter without lens" option when shooting with manual lenses like the Rokinon Cine Primes
  1. MENU → s_menu_cusom.png (Custom Settings) → [Release w/o Lens] → desired setting.
As VTC said you'll want to set the IBIS setting to manual as well and choose the focal length depending on which lens you have attached
