Hi Guys!!!
I'm in need of some pro opinions as research has just confused me more.
Aside from the fact that I should've upgraded my body YEARS ago (currently still rocking a Sony A330), I'm looking for opinions in lens. I currently use a SAL-50F1.8 for portraits and family. My problem comes in when it's a rather larger family and I need to step back further than I have available OR for indoor newborn lifestyle photography where I often like to catch a large portion of the decorated nursery with the subjects, but the limited space doesn't make that possible.
I'm wondering, is there a better portrait lens that I can be using, still with a wide aperture but with a shorter focal length, that I can use as my primary lens? OR Would it be best to buy a wide angle lens for such cases and swap out as needed? If I should just buy a wide angles lens (I'm no where's near familiar with them as I am a portrait lens) which one, because I know distortion can be great.
Overview:
Photography style:
     Portraits/Family
Currently use:
    SAL-50F1.8
Needing:
    better portrait lens with wide aperture but shorter focal length to capture larger areas such as in a room or larger groups
    of families
A must:
    smooth and pleasing bokeh and sharpness
Quick reality check .... I hope that in the years passing
since the birth of the A330 that you've come to realize
that 50mm is slightly tele, not "normal", on APSC ?
Either way, since you're feeling cramped for FoV using
a short tele, you don't need too much of wide-angle FL
to solve the issue. You could get a "normal" for APSC,
which is anywhere in the 28 to 35mm span, and have
the result you want. 35 is "normal", 28 is only just very
slightly toward wide-angle for APSC. Typical kit zooms
for APSC run 18-55mm which is from general purpose
wide-angle [at 18] to the same-as-your-current lens [at
about 50] ... just to put things in perspective [bad pun].
One example of a solution is the old Sigma 28/1.8, a
fast wide-angle for full frame 35mm but a mild-wide to
"short-normal" for APSC. I use it on both formats. It's
not a rare bird. A used one would be a very affordable
compliment to your current 50/1.8 short tele. Thaz just
my own familiar example. I've enjoyed it in 3 different
camera mounts ... still in use for 2 of those. But there's
other similar options if you shop around. There's a 24
f/2.8 from the Maxxum line. I use that more than my
28/1.8 Sigma. It's very compact and focuses very fast
[for a shaft drive lens] cuz it has internal focusing. 24
and 28 are long-time favorites of many users, so you
should find plenty different choices. Faster than f/2.8 is
less common, but certainly not hard to find.
Your remark about bokeh suggests that you'll find fault
with nearly ALL wide-angle lenses. So don't go wider
than you absolutely need for your subjects. The Sony
SAM 35mm f/1.8 may be a great compromise between
wider FoV and control of DoF. It's very affordable new:
https://www.adorama.com/us%20%20%20%20921026.html?gclid=EAIaIQobChMIq_byg_KF1wIVy1qGCh3ixACfEAQYAiABEgI3uPD_BwE
Also relevant:
https://www.thephoblographer.com/2013/07/26/review-sigma-28mm-f1-8-ex-dg-sony-alpha/
I second Username's suggestion of Sony 35mm f1.8 SAM. It will give you a wider view and wide open it has good bokeh and decent sharpness considering the price. If you stop it down it's very sharp. Also, the A330 has a good sensor, so I'm sure you're getting nice pictures, regardless of the age of the camera.
I would also agree with both gentlemen above. When started with primes on my first A mount camera (my beloved A550) the SAM 35/1.8 was the first one. Today I would say it is one of the most underrated lenses. It is "plastic-fantastic", but produces very nice images . Bokeh is ok, albeit a sometimes "nervous" transition area.
So, the SAM 35 is a very unpricy option.
I went a little bit wider during my APS-C time, and got the Distagon 24/2. Expensive, yes - but to my personal taste the second best A mount lens ever made. Although relatively wide it is able to produce a pleasing bokeh once you got used to the focal length.
Color rendition and contrast quality on the Distagon is of the top league.
  • 4 months later...
