I use these on the A7r and the Nex 7.
1) Minolta M-Rokkor (Leica M mount) 28mm f/2.8 (probably my favorite lens ever):
2) Minolta 50/1.2 MD (reasonably sharp even at f/1.2, but just breathing can make you miss the focus):
3) Minolta 200/4 MC (or MD version, optically they should be the same):
And an "outsider / bonus lens", given that is not for everyone because it can be a bit of a "special effect lens" if you don't use it in a certain way: Zenitar 16/2.8 fish-eye m42 (with a Minolta MD adapter).
The one I use all the time is my 28/2.8 Nikkor [pre-AI].
Acoarst, it's not simply that lens as-it-stands. The real
reason is that it's very sympatico with my Lens Turbo.
No significant curvature of field and relatively immune
to the dreaded blue dot syndrome.
Canon FD 20/2.8
Canon FD 24/2.8
Olympus OM 28/3.5
The Olympus sits on my camera when it's parked so it's ready to go at all times.
All of them are used on an A7mII.  I rarely use legacy glass on my aps-c bodies as I never liked the results.  Conversely, I only use legacy glass on the full frame.  That's where the old lenses shine.
Nikkor pre AI 35 1.4
Vivitar 28 2.0 close focus
Canon Fd 55 1.2 silver nose
Best character on full frame, not apsc.....
Pen f 38 1.8. Super sharp center but falls off fast. Also vignettes quite a bit but I love the rendering it gives.
The Nikon pre Ai 35 1.4 is a fantastic lens. I had one of the very first batch, the one with the 9 blades aperture, that even if it was yellow as a lemon (the glass, not the body!) it was a real pleasure to use.
Foolishly I sold it when I switched to Canon...lesson learned: never ever sell one of your favorite lenses.
My list of favorite legacy lensens changes over time - these are the current top 3:
1) Vivitar Series 1 90mm f/2.5 Macro ("Bokitar")
2) Canon nFD 300mm f/4 L
3) Carl Zeiss Vario-Sonnar 80-200mm f/4 T*
My top 3 legacy lenses:
1. Contax Zeiss Planar C/Y 1.4/85
2. Contax Zeiss Planar C/Y1.4/50
3. Contax Zeiss Distagon C/Y 2/28
My No 1 legacy lense:
Here are a few of my favorite non-native lenses that I use most often:
Contax G Zeiss 90mm f2.8
BW Portrait
Fall in the Ozarks
PC-Nikkor 35mm f2.8 (nonAI-early 1970s)
Navy Pier
Chicago
Nikkor 24mm f2.8 (nonAI)
Oak Cemetery
And one in the A mount family - The Minolta AF 100mm f2
Lake Michigan off Navy Pier
Probably the 58mm F1.9 Biotar from Carl Zeiss Jena (not as expensive as the 75 F1.5), very compact and light:
Mush In The Bokeh Room by Henrik Fessler, auf Flickr
Trioplan 100mm F2.8 and its (in)famous Bubble Bokeh
Bokeh Onion Ring Bubbles by Henrik Fessler, auf Flickr
And finally, the Biotar 75mm F1.5
Poppy Field Delight by Henrik Fessler, auf Flickr
I had previously mentioned the 28/2.8 Nikkor for
its tendency to work well with the Lens Turbo, a
cheap SpeedBooster knock-off. Acoarst that tells
you it's for APSC [various Sonys].
You did ask for 3 faves, and now that I've got a
FF Sony, the Lens Turbo no longer dictates which
lenses work best.
Haven't had the FF very long, but old habits die
hard: an old 35/2.0 Nikkor AI has nearly welded
itself to my A7M2 :-)
When I can pry myself away from the 35/2.0, the
other 2 lenses that leap in to replace it are a
20/4.0 Nikkor AI and pancake 50/1.8 Nikkor AI.
The 50 is a pancake on a Nikon SLR body, but on
the FE-to-NF adapter it's not so cute and cuddly
anymore. Still, the whole shebang is more compact
than if I adapt a typical big old 50/2.0 instead.
Those 3 are faves ... real "go-to" gear. OTOH,
3 lenses that see far less use but are a blast
to use for their special applications:
35/2.8 PC Nikkor, a shift-but-no-tilt lens.
105/1.8 AI Nikkor. 1000000X more useful now cuz,
hey, IBIS !!! It's a low light lens with a FL thaz at
the questionable far end of typical handheld use
in pre-IBIS times. Add IBIS and it's a new world !
85/1.5 Soligor. This is a cult lens, whose IQ at
wide open nudges into "Barry Lyndon" Zeiss f:0.75
territory. When you've got that many aberrations
all cooking at once, you don't need any unwelcome
image softening camera shake. And you don't wanna
crank the ISO to extremes, cuz such gauzey imagery
looks really schidty with a heavy does of noise.
So, again, IBIS to the rescue.
So OK, point is, legacy lens-wise, the Lens Turbo is
a very major influence on choosing legacy glass for
APSC bodies, and the IBIS opens up a whole new
rationale for deploying certain FF lenses.
In my post above I wrote:
" Haven't had the FF very long, but old habits
die hard: an old 35/2.0 Nikkor AI has nearly
welded itself to my A7M2 "
I'm normally a nocturnal creature, which means
my pix will seldom show anybody else what they
might get if they were using any of my gear. So
since we were entertaining some highly diurnal
relatives, I grabbed some midday stuff. Voila !
Nikkor AI-S 35/2.0, prolly around f/8, on A7M2
Now don't go pixie peeping on a mid quality jpeg
as required for forum upload. But the RENDERING
against the light is just perfick. Acoarst you
can't judge the corners in this scene, not just
due to the lack of detailed subject matter near
the margins, but also cuz the margins are mostly
deleted. Thaz what the 35mm is all about ... you
frame an intuitive shot on the fly, and trim it
up just a bit when you're no longer in a hurry.
The post above will not allow further
image content [file size limit], and so
here's a scrap of detail thaz hopefully
small enuf to suffer only very minimal
abuse by the limitations of the forum
software/bandwidth:
And I'll add one more post, cuz I can't
fit a second scrap of detail into this
post, due to those same limitations ...
OK, so here's another scrap,
with prolly too much detail ...
even after being ground down
by the forum software:
Kinda scary, yes ?
If you bag an old MF Nikkor
35/2.0 for your A7M2, then
you can be scary too ! ! !
Continuing my daylight adventures
with the MF AI-S Nikkor 35/2.0 and
continuing in the realm of the very
slightly cropped grab shot, I needed
a location shot, and this scene just
begged for the job, and was hired.
IIRC about f/9.5.
IMNSHO, when it comes to grab shots,
a 35 has the perfect amount of grab.
THE 35, VERTICAL FORMAT
It leaves just enuf disposable
foreground for cropping shots
like this one, with a very slight
perspective fix in post ....
About f/11
