Was preparing the A7R MII for a shoot and would be using some lenses from my a99 MII and the adapters would not mount. There seems to be a mechanical blockade. Inspected carefully for any burrs or other impedimenta and found none. The adapters (LA-EA 3 and 4) both mount normally to the a6000. Other adapters (Metabones IV and Sigma MC-11) both mount normally. I have the most recent firmware update installed and the camera worked perfectly with native E-mount lenses. Has anyone ever experience this problem? Any help would be appreciated.
Michael Shier
