Flash Woes - A6000 with Godox TT685s flashes and X1Ts trigger
Hello all.  I'm having one heck of a time trying to use my new flash gear.  It doesn't matter if I attach a TT685s flash directly to the camera's hot shoe or use the X1Ts trigger, all of the images are significantly under-exposed. The flashes certainly flash but that's about it.  I'm thinking I have a wrong setting in my A6000 but I can't figure out what it is.  The camera's flash works fine but the Godox flashes do not work properly. They fire but the image is several stops underexposed.  I am absolutely stumped . . . I've spent hours working on this!! YI yi yi.  (All of the devices firmware is up to date.). The A6000 does communicate with the TT685.
Any thoughts?
  • 1 year later...
