Hello,
I just got a a7s ii . Prior to getting the Camera, I got the Comix adapter, (the cheap one) so that I can use my Sigma 28-70 to work on the camera...
The Lens works, I can shoot... But I CANNOT, control the aperture . It cannot read the aperture..
This is the lens
http://www.the-digital-picture.com/Reviews/Sigma-28-70mm-f-2.8-EX-DG-Lens-Review.aspx
I dont really care for any "auto focus stuff" I just want to be able to control the aperture as normal.  The cheapest solution is what im looking for.
Thanks
-blades
That lens appears to have no iris control ring.
There are adapters, cheap but about $20 more
than the very cheap ones, that have a lever to
control the iris. You don't get an f/stop scale but
usually there's a numbered scale from 1 to 8, to
let you set any specific number of stops away
from wide open [or set wide open, too].
Such iris control adapters move the mechanical
iris actuator lever just inboard of the lens flange.
Hopefully your lens has such a lever. I just this
minute checked a modern Nikkor 18-200 which
lacks any iris ring, and find it still uses the same
old iris actuator lever as Nikon used in 1960 :-)
