What version of Premiere are you using? What PC format are you using?
It's sounds like Premiere is automatically recompressing your videos.
Premiere is in my opinion the best consumer grade photo editing software. But it's also very complicated. You need someone better at Premiere than me. I'd suggest an Adobe Premiere forum.
