Hello to everybody.
I have a Sony A77 with the old Minolta shoe. I bought the Sony adapter ADP-AMA (Minolta to MIS) and a Metz flash, and it works well.
I'd like to try offcamera manual flash, and I found the Yongnuo RF-603II trigger as an option. As far as I understand, they work on cameras with the new native MIS even if they are advertised as for Nikon Canon etc.
Do you know if this trigger will work when mounted on top of the Sony ADP-AMA?
Thanks,
Dario
    • It seems entirely reasonable that they disable a video mode that requires a bit rate faster than any standard SD card can manage to an SD card (SD cards can be rated V30, V60, or V90) - if you try to record a video mode that would require something faster like a "V200" card then they don't let you.  OK, you have some non-standard hack that pretends to be an SD card, but records faster - seems perfectly sensible that they don't support it considering they look at the card to know how fast a rate the card can handle.  Pretty sure that Sony is protecting users who try to use a slow SD card to record a video mode that requires more speed than the card supports, and Sony has the camera say "you can't do that" rather than fail dismally to try to record it - can you imagine the complaints if the user got a recording that stuttered and captured a few frames then a gap then a few more frames? Feel free to complain, but don't expect sympathy. You tried  something that isn't supported, and it didn't work. As far as I know, Sony cameras are the only ones that support two different formats of cards, AND let you have two matching cards of either format. Every other camera that supports two formats has one of each. There are quite a few cameras that support two matching slots, but they only support one format of card (eg: the Z9 support two CFexpressB cards), so you don't have the option of a second format. I like the flexibility - I don't have have enough CFeA cards to cover everything - I can use CFeA for some and SD for others. Yes, CFexpressA cards were fairly expensive in the beginning (back 4 years ago in the A1), and I paid a fair bit for a Sony 180GB CFeA card. But a few years later I spent the same amount for a Lexus CFeA 320GB card, and just recently I spent almost exactly the same amount for a Prograde 480FB CFeA V4 card (which is over twice as fast to load into the computer). The price falls as there is more competition. Interestingly, measurements have shown that cameras like the Z9 cannot write at full speed to their CFeB cards (presumably because they get really hot - they write only as fast as CFeA speeds 🙂
    • If I press record when holding the camera vertically the video will be saved in 9:16 instead of 16:9 and I can't fint any option to disable that feature? It is really annoying having thumbnails being flipped 90 degrees in the editing software as well as having to flip the clips on the timeline. It is also very annoying that it is flipped when previewing the clip both in editing software but also in any media player. It happens really often when doing run and gun video (documentary style).
    • The picture profiles DO NOT affect RAW files. That's been said three times now. Even if RAW is affected by gamma, your custom settings don't affect each other, they aren't global.  Let's back up a bit. First off, which camera are you using? My A7 IV and A1 both have the ability to have completely separate profiles for video and stills.  Why can't you simply set up your video button with the settings you want and just push it? That's what I do. I can be shooting stills and if I decide to shoot video I just press the button. No need to move any switches or press any other buttons.
