Hi guys,
So I've been using  the Nissin Di700 for awhile and its my only real flash experience.  I had a Sony HVL43m but sold it eventually not having much experience with it.
Question:
I was wondering how powerful these all compare to eachother?
I'm looking to buy the B1 as soon as the Air 1 Sony releases, but thought about the B2 instead.  The B1 I believe is 500 Watts while the B2 is 250 Watts total.  To be, I don't know what those watts number mean because I don't know what the Wattage on the Nissin Di700 is.  I can't seem to find info on it, or its being measured in some other way.
I'm not a very technical shooter and flash power is foreign to me.
What are the power comparison to each of these flashes I listed? I want to know to see if It is better to just get the B2.  I do prefer the B2 because of the portability, but at the same time I want something strong enough to power the sun and won't burn out on me like the Di700 constantly do for me when I shoot full power.
The ratings between the camera-mounted flashes and the Profoto flashes are significantly different, and there is no easy way to make a comparison.  Camera mounted flashes are usually rated by Guide Number (GN), which is an indication of the intensity of light leaving the flash tube.  Monolights are rated by Watt seconds, which is an indication of the energy entering the flash tube.
The Nissin Di700 has a GN of 177 feet at ISO 100.  To make sense of this, divide the GN by the distance between the camera and the subject, and the result is the approximate f-stop to use for the correct exposure at ISO 100.  For example, with the Nissin flash and a subject at 22 feet, the approximate aperture setting would be f/8 (177 feet divided by 22 feet).
The comparison to a monolight becomes more complicated because of the variation of light modifiers available.  The difference in reflected light from the subject when using a bare bulb or a parabolic reflector is significant.
Short answer: It's not easy (for me) to make any comparison between the two sources.  Also, depending on location, I don't think you will be able to overpower the sun with a 250Ws monolight.  There are too many variables to consider in order to provide an answer.  For example, what are the exposure settings for the ambient light?  Will your camera and the monolight sync at the shutter speed required to balance the ambient light?  How far away from the camera is the subject?  You might be able to overpower the sun using the 250Ws monolight from a distance of one foot, but I suspect that is not how you intend to shoot.
Before you buy anything, I recommend doing a lot of research to ensure the the proposed equipment meets your requirements.
Despite all the technical difficulty already mentioned,
you're probably thinking "Isn't there at least a really
crude connection between Guide Numbers and Watt
Seconds ?" Yes, very crude, but usable. Figure a top
of the line OEM shoe mount flash as approximately
100 WS. So, you can see that with an efficient bright
reflector a 250WS monolight is a bit more than twice
the power, and therefor about 1 stop brighter.
Usually you will have 2 small monolights, but that is
NOT 500WS for the main exposure, unless you use
the side-by-side [which is ridiculous]. Only the main
light governs exposure. The other is for effect.
Also, realize that you most often do not use a bright
efficient reflector on a monolight as a direct source.
Light modifiers will cost you at least 1 stop.
Today's remarks were brought to you by the word
"CRUDE". Best to keep that in mind :-)
Feeble monolights are for casual indoor use. If you
use monolights for commercial use, 800WS is just a
basic minimum. Much commercial work is shot with
small apertures. Even head shots are shot with fairly
deep depth of field, none of that f/1.2 BS. You need
to get most of the whole head in focus, not just one
eye. The soft-look background effect is achieved by
distance, plus longer FLs. Such DoF at modest ISO,
especially with power-sucking light modifiers, needs
several hundred watt seconds at the main light.
Since commercial work leans toward small apertures
and lower ISO speeds, there isn't much griping about
too-slow synch speeds for a daylight-and-flash blend.
Shooting at wider stops is what provokes complaints
about too-slow synch speed.
...........  I didn't realize monolights and
speedlights are that much different.
That is understandable. Not only is there some
common ground between monolights and shoe
mount speedlights, but advertizing by speedlight
makers shows things like umbrella lighting being
powered by pairs and trios of speedlights.
While this does have some realistic 'historical'
precedent, there's huge cost difference between
a pair of cheap reliable SIMPLE Vivitar 283 shoe
mount flashes and the current fantasy of using
"Speedlights" ... a word whose meaning has now
come to mean powerful expensive computerized
fully automated multi-featured versatile "creative"
grandchildren of those simple cheap 283s.
Ganging up 283s was actually cheaper than using
monolights for similar output. Ganging up digitally
automated "Speedlights" is hugely expensive and
requires major user education ... to learn to speak
"Speedlightese".
The extreme automation of speedlights obviates
any need to understand manually calculated flash
exposure. This appeals to many users who have
been DECEIVED or brainwashed into abhorrence
of any sort of basic operational skill acquisition.
It's ironic that highly flexible versatile automation
presents a maze of options that demands more
user education than it would've taken to just do
everything "the old, hard way". That's the irony,
but it's worse than just irony: Learning the "hard
stuff" is not only easier than learning to control
multi-mode speedlights, but learning the "hard
stuff" almost guarantees that the user will learn
basic principles, while relying on speedlights is
a major impediment to acquiring a grasp of the
basics.
IOW, the marketers have managed to portray
a need for a grasp of the basics as some sort of
boogie man dripping with rabies and ebola, that
automation will protect you from. And, like other
protection rackets, it sinks its claws deeper and
deeper into its victim population.
OK, so I'm sounding like some grumpy oldtimer.
Fair enuf. If you can't grasp the value of advice
from your elders, I have only offered what I can.
I cannot defeat the forces of nature. Darwinism
always culls the herd. You choose to thrive, or
become foodstuff. Freedom of choice.
Here's one workable plan. Get two affordable,
thus low power, monolights. And accept their
limitations. Learn what you can by using them.
The only features needed are variable output
and modeling lights. Convenience features as
a battery power option and wireless triggering
will not impede the learning process. Exposure
automation is just unnecessary complexity and
it WILL impede your progress ... enslaving you
to cumbersome control systems that mask the
reality of what's really going on.
Depending on time, budget, skills progress,
and the type of use you use monolights for,
the simple, low power pair may be all you ever
need, or you may grow beyond that. But you
never actually outgrow them. If you choose to
upgrade your lighting system, that low power
pair remains a useful part of the system to be
hair light, fill light, background wash, etc etc.
So, buy some simple monolights. If the budget
allows, a pair of 400WS. A compromise would
be one 400 and one 250. Don't get just a pair
of 250s ... thaz like assuring defeat in advance.
If all you can afford is a pair of 250s you should
just admit defeat and use the $$ for something
actually useful.
You can use your camera's playback as your
flash meter. Or you can get a flash meter, but
acoarst you'll still be checking the playback to
get a best assessment of your lighting's effect
No shame in that. The top shelf professional
approach used to be using $50 to $100 worth
of instant Polaroid film for "playback", even tho
proper exposure was a given, no problem, and
taken-for-granted. IOW a separate flash meter
is now optional. But, it can be educational fun !
