Hi to all. While searching for legacy Nikon glass I have managed to find someone who has the below pieces in very good to excellent condition and in good prices as well. I might end up buying 3 of them (he offers a discount for more than one) but i am no expert when it comes to legacy glass, their IQ, any pitfalls involved etc.
  • 24mm f2.8
  • 35mm f2
  • 35mm f2.5
  • 35mm f2.8
  • 105mm f2.5 Non AI
I will use them adapted obviously on a A7 and on an A6000.
So, would they be a good match? Are they sharp enough for todays sensors? and lastly which one of the three 35mm would you choose?
Thanks in advance!
  • 24mm f2.8
  • 35mm f2
  • 35mm f2.5
  • 35mm f2.8
  • 105mm f2.5 Non AI
Thanks in advance!
24/2.8 .... typical very good lens. Very useful FL.
You should get this one.
35/2.0 .... outstanding lens. For all I know its lab test
score may be rather ordinary, but real-world it's stellar.
This is the 35 you want, hands down.
105/2.5 pre-Ai .... if it's new enuf to have the textured
rubberized focus ring, it's a fine lens that should be at
a nice price cuz it's pre-Ai. If it's got the metal knurled
focusing ring, I'd pass. That's the earlier formula and
also with rather primitive coating. It's not bad lens. It's
actually good enuf that you'll be thinking, "if this is the
primitive version, the later one must be worth getting",
and you will be right, and it's affordable and available
enuf that you will do exactly that. But, why not just go
directly to step two [if this one is the early version] ?
35/2.8 .... Just pass, or buy it sooper cheap. Until you
get to around f/8.0 it has a dose of "character", which
you may enjoy, but should pay maybe $35 for.
35/2.5 .... IIRC, the f/2.5 speed indicates this is one of
the E-series lenses. It's similar to the 35/2.8, but more
compact and of very light weight, partially plastic build.
When introduced, the build raised eyebrows and noses
but compared to some of today's mid and upper range
lenses, it's build like a vault, or at least a Vaulvo [sic].
For $25 it's a cool lite-weight schlepp-about lens. One
approach would be assign this one as the normal lens
FL for the a6000 and the 35/2.0 is the ultra lens for the
FF body.
Or .... if the seller is just an uninformed peddler who's
flipping merch he knows little about, it could also be the
normal lens from a Nikonos .... useless, non-adaptable.
"Are they sharp enough for todays sensors?"
This is an absolutely sooper stoopid question. Take no
offense, I don't accuse you of inventing it. Do be just at
least a tiny bit embarrassed to have allowed it to seep
into your skull. Take comfort in rejecting this fairy tale.
How REAL WORLD SHARP are they ? Well they are
sharp enuf that, handheld below about 1/250, YOU, as
the camera's physical support, are the reason for less
than very good to excellent IQ. Therefore, what you call
an "a7" is hopefully actually an a7-MkII so you have the
benefit of IBIS, which gives these lenses a much better
opportunity to show what they can do.
I own most of the versions I mentioned, and previously
owned those not currently on hand. None of them are
bad lenses, but where there are better versions, since
the price difference is not much, most buyers hold out
for the better version. All the lenses are very available,
so none are actually expensive or rare opportunities.
Of the lenses listed, the most outstanding imagery will
come from the 35/2.0 Ai [iMNSHO]. If you are more of
a "pictorialist", you may prefer the 105/2.5 [if it's the
rubber focus version] as most outstanding. Let's not
forget the 24/2.8. Do get that regardless what else.
Haha, I don't think I was ever accused of being stupid and enjoy it so far! Anyway, I get your point and many thanks for a -once again- thorough reply.
The 35mm f2 does seem nice and most probably I will get that. As far as the 105mm I still haven't seen any photos of it so I am not sure which version really is but I will keep what you say in mind.
The 24mm f2.8 is probably a good choice too but I also have a 28mm f2.5 Tamron adaptall 2 so I am not so sure about buying another one on such a close FL.
And now the really interesting part IMO, I forgot to mention that this seller also has a Nikkor 18mm f4 AI. I had originally removed it from the "possible" list since it is much more expensive but I do need an UWA now especially since on the A6000 the 28 or 24mm are not wide enough for me.
hmmmm...
DO NOT buy the 18/4.0. Set ME up to get it :-)
Seriously, I don't want the f/4.0. I'd mean what
I wrote above if it were the f/3.5. It's not about
the speed it's about the insane filter size of the
f/4.0 ... series IX, vs 72mm on the f/3.5. And I
actually HAVE the filters for the series IX but
would hold out for the 72mm model. And that
would be true only if the dog at my 20/4.0 so
that 18mm would not be nearly redundant ;-)
Hello! Well, personally, I prefer using a little bit different lens, namely 58 mm. I found an old Helios - http://helios44-2.com 58 mm f/2, it draws pictures perfectly. I connected it with the M42 coupler, and I have no problems with it at all. It is a great lens for this money, it perfectly blurs the background of the picture and has a manual focus. If you are interested, just try it. I think it will fit you!
