HDR Bracketing with A6300
My A99 can do white balance and exposure bracketing, requires a tripod or to keep the camera in the same place via another method. I'm sure the A6300 can do something similar.
Or are you looking for an automatic software HDR setting that saves the image out to RAW?
As far as I know the HDR mode on the A6300 saves out to a JPG.
I'm looking to shot brackets of RAW shots for use with
HDR Efex Pro or Photomatix Pro, is this possible?
Seems to me you just set up auto-bracketing and
select Raw as the file type/quality. If you don't get
as many frames as you need, shift your [manual]
exposure and repeat AEB.
  • 1 year later...
