Hi i have a sigma 150 / 500 lens i use it on the Sony a77 mark2. When i come to take a photo the image is clear but when i take the photo it is not sharp. I do have the image stabilizer switched on on the lens and the steady shot turned of on the camera. But even with the cameras steady shot on the results are the same. Hope someone can point me in the right direction. Thank you once again.
Thankyou Colem for getting back to me. I will look into how to do that as I don't know how to. When ever I'm in setting A or S when looking through the view finder the image is steady but when I half press the shutter button the image starts to become unsteady. As if the image stabilizer is working in reverse. Thankyou again for your input it is really appreciate.
Try turning off all stabilization and see what happens.
Try a best case test also.  Use a sturdy tripod and a subject that is not moving, like something indoors and take a photo without touching the camera, 10 second timer.
If you are still getting poor results or reverse image effects when you are testing under the best scenario, then you can start looking at what is at fault.
    • I elected to upgrade from Sony A1 to the A1 ii and am seeing some significant focusing challenges in the little time I've spent with it so far. Less than 10% of photos appear to be in focus when photographing small birds in subject mode birds with seemingly no improvement when subject mode is changed to birds/animals/people. Scenario: Sony A1 ii, 200-600 G lens @ 600mm, F6.3, shutter speed on male cardinal (in-focus mostly) at 1/250 ISO 125 and female cardinal (nothing in focus) at 1/1600 ISO 100; AF-C set with eye supposedly in focus in both shots. Lens has AF on, OSS on, Mode 1. I've tried switching out lenses using 100-400 with and without 1.4X converter and used handheld and used tripod. Photos are at a distance of 20-25 yards. The photos below are within a couple yards of one another. There is seemingly no improvement in AF performance despite the combinations of lens, tripod and focus zones attempted. Birds are stationary. Many of the photos will have everything in the frame seemingly out of focus and some may have the head in focus and rest of body out of focus and immediate area around bird slightly out of focus at F9-F11. I considered that I was cropping too much and had pixel peeping / expectations problem, but some photos are wildly out of focus when supposedly focusing on eye or body. Neither photo below is cropped. Ideas are welcome!
    • Agreed, but it's ancient thinking. Any modern forum lets you edit whenever. It's simply a setting they could click to turn off. It's one reason I won't post many photos here. After 10 minutes I lose complete control over my own property.
