Guest Peter Kelly
Do you meant that the gauge is not showing green at all, even when the camera is level, or that when the green is lit that the camera is not correctly horizontal?
Unfortunately, to be honest, I don't think there is a user fix in either case. I'm not sure what might cause the green not to light up, but if the camera is still at an obvious angle when it is lit could mean that the anti-shake has failed, or the sensor is mis-aligned. In either case I think it will have to be returned to Sony for calibration, or repair.
