December 5, 20159 yr Need advice on quality, durable tripod ball heads with arca-swiss mount, that won't break after a couple of years. Up to $350. Any suggestions?
Advertisement Hello JonathanStewart, You may be interested in this: Recommendations on Tripod Ball Head? . I'm sure you'll find what you were looking for!
December 5, 20159 yr If you can live with the weight and size the Arca Swiss Monoball B1 it is bloody fantastic. I bought one used a few years ago for 99€ (cheap because a bit of the plastic on one of the gears was chipped). The only time I notice a bit of "play" when focusing my images (and even then it is probably the Contax > Olympus adapter that's not that rigid or the lens tripod collar, and not the B1 fault) is when using the Contax 100-300 with a 2x on the Olympus E-M10 for a 35mm equivalent focal length of 1.200mm (for astro stuff, obviously). To put things in perspective, it is the same tripod head I used to use with my Linhof Technica 13x18cm / 5x7" large format camera. Used with the A7r is rock solid.
December 5, 20159 yr Author If you can live with the weight and size the Arca Swiss Monoball B1 it is bloody fantastic. I bought one used a few years ago for 99€ (cheap because a bit of the plastic on one of the gears was chipped). The only time I notice a bit of "play" when focusing my images (and even then it is probably the Contax > Olympus adapter that's not that rigid or the lens tripod collar, and not the B1 fault) is when using the Contax 100-300 with a 2x on the Olympus E-M10 for a 35mm equivalent focal length of 1.200mm (for astro stuff, obviously). To put things in perspective, it is the same tripod head I used to use with my Linhof Technica 13x18cm / 5x7" large format camera. Used with the A7r is rock solid. That does look pretty good. Thanks.
December 5, 20159 yr I am selling a Really Right Stuff BH40 with B2 screw-knob style quick-release clamp in excellent condition, if you are interested, for 200 euros.
December 5, 20159 yr The RRS BH-40 is the perfect compromise in the BH-xx lineup. Another interesting choice are the Acratech ballheads. Very light, yet strong.
December 5, 20159 yr I use an Arca Swiss Monoball Z1 head with a Really Right Stuff B2-LR II quick release clamp for my D810. http://www.bhphotovideo.com/c/product/469920-REG/Arca_Swiss_801102_Monoball_Z1_sp_with.html http://www.reallyrightstuff.com/B2-LR-II-Lever-release-clamp This is pretty heavy duty and outside of your budget. For my travel tripod and for a more suitable size for the Sony A7 range, I use a Really Right Stuff BH 30 http://www.reallyrightstuff.com/BH-30-LR-Compact-ballhead-with-B2-40-LR-clamp I also use Really Right Stuff L brackets and lens clamps exclusively. They make the best gear. I favor Gitzo carbon fiber tripods and monopods over Really Right Stuff, purely on price. I don't feel that Really Right Stuff adds much for the extra money. HTH
December 14, 20159 yr I've been researching this subject for over 4 weeks and it's tiring me out!! I don't want to spend a fortune, I want quality and I don't want it to be too big - so I've decided on the Cullmann Magnesit MB4.4 https://www.cullmann.de/en/detail/id/magnesit-mb-kugelkoepfe.html Made in Germany, and around £130 here in the UK. D.
