I'm curious, has anyone used both the A-mount (FF) Zeiss 24mm F2 and the E-mount (APS-C) Zeiss 24mm F1.8 lenses from Sony?  If so how did you find the performance to compare?  Is one sharper than the other, focus quicker than the other, etc.?
I like the idea of the A-mount just because I can also use it on my A-mount cameras (including the FF models), but since I use my a6000 more than anything these days, I'd probably settle for the e-mount (faster and less $$) if it performs as well or better than the a-mount lens.
Thoughts?
