Guest Peter Kelly
The Di700 is very good and can be used for off-camera flash with the 'Air commander'.
However, for a lighter, simpler, and more balanced flash on the A7, I can't recommend too highly the Nissin i40. It can't be used off-camera without third party triggers (and won't do HSS/TTL in that case), but it really does work very well and suits the size of the A7 perfectly. If you do go for the Di700 I would certainly get the Air commander kit, as it isn't much more expensive than the flash on its own and gives you the flexibility, which can be expanded with more flashes later.
The bottom line is that both Nissin units are much better value than anything from Sony, even though the Sony are very capable and well made.
I have two Sony flashes (HVL 20 & 43) and a Phottix Mitros + along with a separate Phottix Odin for a two flash off camera setup.  Just getting into off camera flash so I still have a lot to learn.  But I know the Sony flashes work well and are durable.  I was moving the HVL-43 down the stairs and it fell off a light stand a distance of almost 2 meters.  No damage and working perfectly.  As for the HVL 20, this is really my favorite flash for travel.  I have fast primes and rarely even need flash so the HVL 20 is usually all I need.  Of course it does not do high speed sync.  But it is really small and light...great for travel.
Do you experience much overheating with your Sony flashes? HVL-43? The overheating issues scare me a bit
I have ALL the Minolta (D) and HS(D) flashes from 2001 up and ALL the Sony flash models for A-Mount (AM suffix) and with MIS shoe (M suffix)
ALL flashes can overheat and this kills them prematurely. Normally it does not die on you the day it overheated but on the next outing when you don't expect it. My older Minolta and Sony Flash units (3600/5600 Minolta's and Sony HVL-F36AM and 56AM did not have any protection) have probably survived because they were never abused over and over and since most of them were purchased used, i live a happy life.
Newer and higher-end flash models now have this overheat protection that kicks in if the flash detects a certain temperature. This heat is usually caused by 2 parallel phenomenons only when there is a long sequence of quickly taken pictures ( 10 pictures a minute for 3 minutes or more for example) :
- the batteries trying to provide a lot of power quickly to recycle the capacitors generate heat
- the capacitors releasing their energy and being recycled over and over generate heat 2 times
The fact that both the batteries and the capacitors are so close in an enclosed housing ( your flash), makes heat dissipation difficult and the overheat you are afraid of will only occur under these extreme conditions. I hear but can not confirm that Canon has a menu item in some of its flashes that can disengage the overheat protection but i am sure their warranty is finished the minute that option is chosen by the user.
I did overheat my HVL-F43M once taking about 40 high power pictures in succession. It stopped working for a few minutes and since i had others on hand, i just switched to another one. However, i an sure it will last long in spite of this isolated event
By the way, over and above overheat, the other 2 things that kills flashes prematurely:
- Leaving the batteries in when you don't know when you will use it next (leaked batteries probably killed more electronic flash units over the years than any other cause)
- Not using the flash for an extended period of time ( it is in the owner's manual of every flash i own that they should be recycled and powered off 2-3 times every 3 months or so and left on for 30-60 seconds after the flash-ready light is on to give some exercise to the capacitors which are electro chemical components that need this kind of regular use otherwise they dry up )
I just use any old flash, as long as it has low trigger voltage.
My old 283 tested at over 100 volts, so it's useful only as a
slave flash, but my 285 trigger runs about 12v, and an old
Nikon flash is only 7v, so I use those and other oldies such
as Minolta Maxxum flashes.
Such flashes use aperture dependent exposure automation
and you hafta monitor your own shutter speed for synch. A
major advantage of the simple flashes is the lack of delay.
Whatever your camera's best [aka minimum] delay is, from
tripping the shutter button to actual image capture, it fully
remains that fast. Exposure is governed in real time, during
image capture. Off-the-film flash automation had the same
speedy action. But there is no off-the-sensor version of that.
Digital flash exposures are calculated from test pulses prior
to the actual image capturing exposure, then that calculation
is transferred to the flash-and-camera for use during actual
image capture. Two steps vs one step. Less is more here.
my brain hurts trying to figure out the best flash!
There is no such thing as the best of anything
depends on what you intend to use it for.
Always on camera ?
Need power for bounce off ceilings or others ?
Need for WL TTL ?
If so how sophisticated will the system expand to ?
Need for Manual TTL ?
Using a lot of adapted vintage lenses ?
Use outdoors in WL ?
I could go on and on since every flash has its compromises and can fit some needs but may be overkill for others
    • From my records, Minolta made about 8500 85mm F 1.7 lenses bearing the MD badge. The MC-X version was slightly double that. So these are not that rare. I just saw an ad for a Limited Rare MD 45mm F2 lens ( Minolta made over a million of these) so the word rare is often used in a bizarre way. Seeing that the OP has a MD ROKKOR-X version and that he appears to have bought it from Europe is kind of unusual since the ROKKOR-X versions were to be sold exclusively in America. So in Europe, this lens naming was rare.  I think the confusion about a reworked version may come from the fact that during the MC-X era (1972-76), Minolta made numerous changes to their lens line-up. First they changed the lens Mount Index dot which was initially painted like their previous series of lenses but after about 1 year, they replaced this with a slightly larger diameter plastic bead. This change happened around the introduction of the X-1, XM, XK bodies. Then they removed the small Stop Down Levers that were on most lenses up to now around 1975 since their SR T and XK/XE bodies were now boasting a Stop down mechanism. Then a little later Minolta even removed the lens formula (in this case PG) designation from the lens markings. This may have caused people to believe there was some kind of modification to the lens when it was only a marking  change. Also around 1973-74 they decided to provide a different marking for lenses sold in America ( at least USA and Canada) to identify lenses sold on the grey market that was often cause for confusion with consumers buying a great deal they could not get repaired under warranty. Same applies to Bodies starting in the same era where  X-1 was for Asian market, XK for American market and X-M for rest of the world, then SR T 102 in America, SR T Super in Asia and SR T 303 in rest of the world. So you could find all of the following with their respective front markings: - MC-II: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL) This type has the hills and valleys metal focusing ring -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Painted Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X marking for the American market) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index, Orange colored ROKKOR-X) -MD-II: MD ROKKOR 85mm 1:1.7 ø55mm -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (Orange colored ROKKOR-X again for the American market) -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (White colored ROKKOR-X ( iguess orange paint was getting too expensive) ) It was then replaced with the MD-II MD ROKKOR (X) 85mm F 2 There was no MD-I version of this lens and the same with a few lenses with large apertures ( 35mm F 1.8, 58mm F 1.2, 300mm F 4.5) since they had issues with the speed of the aperture mechanisms closing down for what was  a last minute check on XD/XD-7 and XD-11 bodies requiring stopping the lens down just prior to the shutter opening to ensure accurate exposure. Some late MC-X lenses may have had the modified aperture mechanism causing the confusion that there was an updated version but the optical formula seems to indicate there was no change.
