  I just purchased the A99 with Zeiss 24-70 2.8 and its kind of confusing setting it up. I do mainly Portraits and weddings and need help with the usual settings for these . I would like a tutorial video if there are some available or forum members that can share their settings.  Thank you
    • Shooting a cactus flower is probably where you do want to have nice bokeh. I can't recall which camera you're shooting, or maybe you haven't said, but using live view you can see what the shot will look like before you press the button. Try setting up on a flower or something stationary where you can control the background and see the changes different settings make.
