I'm looking online for an M42 flanged adapter for my A77 so that I can use a Zenitar M 50mm f1.9 lens, which has an aperture pin. I haven't had any luck finding such an adapter for the A Mount. Does anyone know where I can find one to buy? I already have an M42 adapter without a flange, but this Zenitar lens' aperture blades can't be adjusted on the adapter, so the lens is always wide open.
    • Shooting a cactus flower is probably where you do want to have nice bokeh. I can't recall which camera you're shooting, or maybe you haven't said, but using live view you can see what the shot will look like before you press the button. Try setting up on a flower or something stationary where you can control the background and see the changes different settings make.
