I encountered the same problem on my Mac....can't get in.  No problem with my PC.
If you disable pop-ups in Safari preferences, you will be able to go
It happened a couple of weeks ago, then got OK and it is now back to this ridiculous redirection
    • Shooting a cactus flower is probably where you do want to have nice bokeh. I can't recall which camera you're shooting, or maybe you haven't said, but using live view you can see what the shot will look like before you press the button. Try setting up on a flower or something stationary where you can control the background and see the changes different settings make.
