I’m looking to trade in my Nikon Z6ii - heavy, restricted and expensive lens choice being the main reasons. Having considered moving to either a Sony A7iii or iv or the R versions of these, I would be grateful for first hand advice on the pros and cons of such a move. I shoot mainly landscape, street and travel and not so much portrait, wildlife or macro.
There's a lot to consider -- many options with different pros & cons.  Use the SEARCH feature (upper right corner of this screen) for something like "MOVING TO SONY" or "WHICH A7" and you'll see previous discussions.
    • From my records, Minolta made about 8500 85mm F 1.7 lenses bearing the MD badge. The MC-X version was slightly double that. So these are not that rare. I just saw an ad for a Limited Rare MD 45mm F2 lens ( Minolta made over a million of these) so the word rare is often used in a bizarre way. Seeing that the OP has a MD ROKKOR-X version and that he appears to have bought it from Europe is kind of unusual since the ROKKOR-X versions were to be sold exclusively in America. So in Europe, this lens naming was rare.  I think the confusion about a reworked version may come from the fact that during the MC-X era (1972-76), Minolta made numerous changes to their lens line-up. First they changed the lens Mount Index dot which was initially painted like their previous series of lenses but after about 1 year, they replaced this with a slightly larger diameter plastic bead. This change happened around the introduction of the X-1, XM, XK bodies. Then they removed the small Stop Down Levers that were on most lenses up to now around 1975 since their SR T and XK/XE bodies were now boasting a Stop down mechanism. Then a little later Minolta even removed the lens formula (in this case PG) designation from the lens markings. This may have caused people to believe there was some kind of modification to the lens when it was only a marking  change. Also around 1973-74 they decided to provide a different marking for lenses sold in America ( at least USA and Canada) to identify lenses sold on the grey market that was often cause for confusion with consumers buying a great deal they could not get repaired under warranty. Same applies to Bodies starting in the same era where  X-1 was for Asian market, XK for American market and X-M for rest of the world, then SR T 102 in America, SR T Super in Asia and SR T 303 in rest of the world. So you could find all of the following with their respective front markings: - MC-II: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL) This type has the hills and valleys metal focusing ring -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Painted Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X marking for the American market) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index, Orange colored ROKKOR-X) -MD-II: MD ROKKOR 85mm 1:1.7 ø55mm -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (Orange colored ROKKOR-X again for the American market) -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (White colored ROKKOR-X ( iguess orange paint was getting too expensive) ) It was then replaced with the MD-II MD ROKKOR (X) 85mm F 2 There was no MD-I version of this lens and the same with a few lenses with large apertures ( 35mm F 1.8, 58mm F 1.2, 300mm F 4.5) since they had issues with the speed of the aperture mechanisms closing down for what was  a last minute check on XD/XD-7 and XD-11 bodies requiring stopping the lens down just prior to the shutter opening to ensure accurate exposure. Some late MC-X lenses may have had the modified aperture mechanism causing the confusion that there was an updated version but the optical formula seems to indicate there was no change.
