i have a problem with a9ii when using usb-c power and external monitor ac powered, i get very bad interfence noise and hissing from external microphone plugged in to camera.
i have to unplug both usb power and hdmi cable before i get clean audio again. i think the monitor or its ac adapter (feelworld 759) is the problem here?
i can use external recorder. But is there any real solution? And does anyone else have this problem?
Sorry for bad english
    • If I press record when holding the camera vertically the video will be saved in 9:16 instead of 16:9 and I can't fint any option to disable that feature? It is really annoying having thumbnails being flipped 90 degrees in the editing software as well as having to flip the clips on the timeline. It is also very annoying that it is flipped when previewing the clip both in editing software but also in any media player. It happens really often when doing run and gun video (documentary style).
    • The picture profiles DO NOT affect RAW files. That's been said three times now. Even if RAW is affected by gamma, your custom settings don't affect each other, they aren't global.  Let's back up a bit. First off, which camera are you using? My A7 IV and A1 both have the ability to have completely separate profiles for video and stills.  Why can't you simply set up your video button with the settings you want and just push it? That's what I do. I can be shooting stills and if I decide to shoot video I just press the button. No need to move any switches or press any other buttons.
    • Yeah, but it means that if the PP affects the RAW then if you are an hybrid shooter (photo + video) that's not ideal right? No you can't. You can't have separate custom profiles for video and images. When you enable picture profile, the creative look (PP in photo mode) is grayed out. Yes you can configure the custom setting button but that is one extra step. Canon has got custom button 3 mapped to record button.   The ISSUE here is that when you are in photo mode you have to: 1) Turn the dial to the custom setup you want 2) Switch to video mode 3) Press record Canon has got the custom button 3 mapped to the record button. What does it mean? You are in photo mode and I just need one step: press record button and it will record with the setting pre-set on custom button on the dial. But one thing that bothers me massively is the fact that the PP affects the RAW.   Is there a way to speak with Sony? Do they have any platform where we can give them inputs? This should an extremely easy firmware update (custom button on the dial mapped to the record). The PP affecting the RAW that I am not sure but it should be very easily fixed I believe unless it's got to do with the architecture of the circuitries inside the camera, etc.
