Triggering 3 Sony a6x00 cameras at the same time
What is the best way to trigger 3 Sony cameras at the same time, one a6600 and 2 a6000 ? A wired solution would be great as the camera will be mounted together on a hand held rig for photogrammetry purposes. I'd like to trigger them from a push button.
Would this be easier with 3 Sony RX0 ii cameras instead of the APS-C cameras?
