Sony A7R5 LCD and viewfinder issues
Novic
What I see at my Sony A7R5.
I’ve shot remotely using phone and imported JPG + raw
The LCD on Sony is cool and brighter even if  Screen brightness is -1 than imported JPG and Raw. The same if I import this test to the computer and use C1, LR, PS, native sony software, DXO and even FastViewer for jpeg
 DRO is off, Picture profile is OFF, Creative style – standard. WB – manual Kelvin
 Viewfinder (-2) is brighter than screen (0)
 It seems the problem is not associated with camera profiles in C1 or whatever. It’s associated with wrong LCD and viewfinder color and contrast in Sony
Brightness of viewfinder and screen is manual
What thoughts?
Hi, the only thing I can think of is whether "Live View Display - Setting Effect is ON or Off.  This is supposed to show you what the final image should look like, or provide a brighter display for duller studio environment.  Forgive me if this is not useful as I have only had my A7R5 for a couple of weeks, so I am still a novice just trying to help.
