A7Siii - video clip came out in low res, blurry quality
Frisbee
Hi,
I recently used my A7Siii as a locked off second camera on a shoot. After 20/30 mins the shoot was interrupted. I stopped recording and changed the battery then hit record for another 15 mins. No settings or focus etc was changed. But when viewing the two clips back the second clip was fine but the first looked blurry and ‘unrendered’. I dual recorded and it was the same on both cards. I rescued the shoot by adding sharpening in the edit which brought the footage back to normal again. Anyone experienced something like this?
