Studio Strobe help needed
Spacecoastbill
I moved across the Country and all my studio stuff was "misplaced".
I have an Alpha A65
I have the studio lights, and strobes but I need some help with other items I need.
I know I need some trigger for the strobes, I was thinking of getting something wireless
A remote for the A65
And something to make the triggers work.  I forget what I had but it was something that went on the hotshoe and worked with the strobe triggers
If anyone has any specific parts they like, or ideas for what Im missing, I would appreciate the help.
THANKS
  • 2 months later...
