Alpha 7iv compared to 7Siii - HD 1080i full frame versus Super 35 (APSC)
Lutz
Most grateful if anyone has experience of shooting 1080i and outputting via HDMI to an external recorder.
The objective is to record to ProRes 422 or DNX120, then ingest into EVS and then play inserts into pre-game coverage of live sport TV broadcast.
Recording 1080i on a full frame sensor is the preferred route rather than on Super 35/APSC cropped. This to give minimal depth of field so as to lose the background. Hence the requirement for Sony continuous eye AF in video mode.
A recent YT video suggests that its best to shoot on Super 35 on the A7Siii rather than FF which detracts from the shallow DOF objective.
Very much appreciate your thoughts on whether I can achieve high quality 1080i when recording full frame on these cameras and which would produce the better results.
Furthermore has anyone shot HD 1080i video in indoor sports venues with LED boards behind and might the variable shutter on the A7iv be useful in case of tricky flicker issues?
